Resetting Operation Text
Operation text that has been manually entered may be reset to its original value by following the following steps:
• Right-click to select the row and open the option menu.
• Select Reset Operation Text. The Reset Operation Text dialog box will open to confirm that you want to change the Operation text back to its original value.
• Click Yes to reset the value.
Note: Click No to close the dialog box and leave the Operation text unchanged.
