Use the View Areas tab to save and load view areas. The first row in the View Areas table contains a special Dynamic View (All Assets) that contains all assets associated with the switching sheet; as assets are added in steps, the dynamic view is automatically updated to include those assets.
The View Areas tab displays the following fields and buttons:
• The Auto-Load in Viewer drop-down list allows you to assign a view area to a Viewer, which will then load that view whenever the sheet has focus. Note that the auto-load function does not open the Viewer so you must start the Viewer to see the view areas.
• Description is the description of the saved viewing area. The default description is "View Area #," where "#" is a uniquely generated ID number. You can change this description up until the associated switching sheet has reached the Completed state. The All Assets (Dynamic View) description is not editable.
• The Save View Area 1 button () allows you to save the map area that is currently displayed in Viewer 1.
• The Save View Area 2 button () allows you to save the map area that is currently displayed in Viewer 2.
• The Load View Area on Viewer 1 button () allows you to load the selected viewing area to Viewer 1.
• The Load View Area on Viewer 2 button () allows you to load the selected viewing area to Viewer 2.
• The Delete View Area button () allows you to delete the selected viewing area.
• The Reload All Viewers button () allows you to reload all viewing areas marked for auto-loading.
