Loading a Saved Viewing Area
After a viewing area has been saved for a switching sheet, you can quickly load the viewing area into the Viewer window.
To load a saved viewing area, complete these steps:
1. On the View Areas tab, select the viewing area you want to load.
2. Click the appropriate button to load the viewing area into the desired Viewer (or use the right-click context menu options):
• Click
Load View Area on Viewer 1 button (
) to load the selected viewing area to Viewer 1.
• Click
Load View Area on Viewer 2 button (
) to load the selected viewing area to Viewer 2.
The selected viewing area is displayed.
Note: If the Viewer you selected is not running, a message is displayed.
