Removing an External Document
To remove an external document from a switching sheet, do one of the following:
1. Click the External Documents tab.
2. Select the document in the table.
3. Click the
Delete button (
Note: Alternatively, right-click the document and choose Delete from the context menu.
The status of the selected document is set to Deleted, and the file is displayed in red.
4. Click the Save Sheet button to save your changes. The document list is updated and the file is removed from the database.
Note: The file is deleted from the database, but the local copy of the file on your PC is not removed.
