Menu Option | Description | Toolbar Icon |
Sort Dialog... | Opens the Sort Dialog, allowing you to create, modify, apply, and save user-defined sorts. See “Using the Sort Dialog Box”. | -- |
Sheet # | Applies the default sort, which is the sheet # in descending order. | -- |
