To create a new Stand Alone Safety Document from the Web Workspace, from the File menu, select New, and then select Safety Document... The New Safety Document window will open.
Note: You may click the toolbar button () rather than the File menu.
From the New Safety Document window, you may create a safety document based on a blank template or from a pre-existing safety document.
Create a New Blank Safety Document
To create a blank safety document from the New Safety Document dialog box, do the following:
1. Select a safety document type from the Safety Document Type list.
2. Click Create; the new safety document will open.
Create a New Safety Document with Existing Safety Document Data
You may want to create a new safety document with data from an existing safety document; for example, creating multiple safety documents types to be used in a multi-step switching operation.
1. Select a safety document type from the Safety Document Type table.
2. From the Pre-Created Safety Documents table, select an existing safety document that has the data you need for the new document.
3. Click Create a Copy; the new safety document will open and be populated with asset data from the pre-created safety document. The Create a Copy button will only be visible after you have selected a safety document type and a safety document within the pre-created safety document list.
