3. Select one of the assets in the Tag Points list and click the Delete button () to remove the asset.
Note: The Remove option is only available when the document is in the New or Unissued state.
4. Open the Miscellaneous Log and note that it now lists the Place Tag operation step that was removed from the safety document.
The associated action step will only show up in the Miscellaneous Log, after being removed, if the action was recorded from the Real‑Time Control Tool. If the asset was recorded as a selection from the Viewer, then the asset will simply be removed and no action steps will be moved to the Miscellaneous Log.
