Menu Option | Description | Toolbar Icon |
Refresh | Refreshes both the Pending Maps and Patches lists. | |
Halt Model Build | Stops all model build activity. See “Enabling and Disabling Model Building” for more information. | |
Enable Model Build | Enables model building activity that was previously halted. | |
Run Full Model Build | Rebuilds the entire system model, not just individual maps. | -- |
Run Post Process | Runs the post-processing script. Post processing takes place after maps are built. The default post-processing script performs a recompute and recache of the control zones in DDService, but this can be modified to perform various tasks, such as generating control zones or computing EE details from the model. | |
Enable Model Build Reporting | Enables or disables model build reporting. The Model Build Report lists all objects that were modified when a particular patch was applied. If enabled, a checkmark appears next to the menu option. | -- |
Build Map | Prompts you to enter one or more map names and then rebuilds the specified maps. If you are entering multiple map names, separate names with spaces, as shown below: Landbase_49132336 Primary_49132336 |
