Adding an Option
To add a new option to an option menu, complete the following steps:
1. Select the Event Type whose option menu you wish to change.
2. Select the option menu you wish to change from the Event Details Option Menus drop-down list.
3. Click
Add. The Add/Edit Option dialog box appears.
4. Enter the new option name in the Option Name field.
5. Leave the Display Menu field blank.
6. If the option is being added to a submenu, enter the name of the submenu in the Submenu field.
7. Click Save. The Options for Currently Selected Menu table updates with the new option.
Note: If the option name already exists, an error will appear and you will have to modify the name.
