Editing an Option
To edit an existing option, complete the following steps:
1. Display the Event Details Options tab on the Configuration Assistant window.
2. Select the Event Type whose option menu you wish to change.
3. Select the option menu you wish to change from the Event Details Option Menus drop-down list.
4. Select the option you wish to edit from the Options for Currently Selected Menu table.
5. Click the Edit button. The Add/Edit Option dialog box appears.
6. Make the desired changes.
7. Click Save to save the new option. The Options for Currently Selected Menu table updates with the edited option.
Note: If you enter the name of an option that already exists, an error dialog box appears.
