The Schematica Options tab allows an administrator to configure the options for the initial schematic generation.
Understanding the Schematica Options Pane Components
The Schematica Options tab allows you to add, edit, remove, and execute the contents of each of the option. The Schematica Options tab displays the following fields and buttons:
• The Schematica Options Pack drop‑down list allows you to select the option package to use for schematic generation.
• The Options Category radio buttons allow you to the view options categorically for the selected option package (for example, execution options, feeder extent options, feeder grouping options, layout options, advanced layout options, class specification options).
• The Options settings for selected option pack table populates with the currently configured options for the selected option package and category.
• Buttons
• Create Copy: Allows you to create a copy of the existing option package.
• Add: Allows you to add a new option to the selected category for the selected option package.
• Remove: Allows you to remove the selected option.
• Edit: Allows you to edit the selected option.
• Run: Allows you to run the schematic generation for the selected option package.
• Export Configuration...: Generates SQL statements for the current state of the configuration associated with the Schematica Options tab. These SQL statements may then be saved to a file and/or printed.
