Creating a Copy Pack
Create Copy allows you to create a copy of the existing schematica option packages. The copy may then be edited to add new options and modify existing options. To create copy for new option package, complete the following steps:
1. Click
Create Copy.
2. In the Copy Option Pack dialog box, select the copy pack from the Copy Pack drop‑down list.
3. In the New Pack field, enter a name for the new pack.
The Schematica Options Pack drop‑down list will display the new option pack and the Options settings for selected option pack table will display the initial options in the copied pack. You can then modify the pack options.
