Adding an Option
To add a new option to an option package, complete the following steps:
1. Select the option package from the Schematica Option Package drop‑down list that you want to add the new option to.
2. Select the category form Options Category.
3. Click
Add. The Add/Edit Option dialog box appears.
4. Enter the new option name in the Option Name field.
5. Enter the option value in the Option Value field.
6. Click
Save. The
Options settings for selected option package table updates with the new option.
Notes:
• If the option name already exists, an error will appear and you will have to modify the name.
• Option names and syntax are documented in The Oracle Utilities Network Management System Configuration Guide.
