Removing an Option
To remove an option from an option package, complete the following steps:
1. Select the option package from the Schematica Option Package drop down from which you wish to delete an option.
2. Select the category form Options Category under the option you wish to delete belongs to.
3. Select the option you wish to remove from the Options settings for selected option package table.
4. Click
Remove. A confirmation dialog box appears. Click
Yes to remove the option; click
No to cancel the removal.
