Buttons
• Add: Opens the Add Default Restoration Time dialog box.
• Remove: Marks the selected default restoration time for deletion.
• Save: Saves any changes you have made.
• Refresh: Refreshes the screen. If you have any unsaved changes, the system asks if you want to save them.
• Export Configuration: Opens the Generated Configuration window, which displays the SQL statements used to generate the current configuration.
