Buttons
• Add Limit Band...: Displays a dialog box that allows you to add a limit band.
• Edit Limit Band…: Displays the Add/Edit Limit Band dialog box to edit the parameters of the selected Limit Band.
• Remove Limit Band...: Displays a dialog box that will allow you to remove the selected limit band or cancel the action.
Note: A limit band ID can only exist once in a single limit set. The band IDs should have no gaps between them.
