• Add…: Opens the Add / Edit Alarm Priority dialog box to allow a new priority to be created.
• The Remove…: button Deletes the selected priority.
• Edit…: Opens the Add / Edit Alarm Priority dialog box with the selected rows values.
• Refresh: Refreshes the screen.
• Recache Services: Causes the Oracle Utilities Network Management System services to recache with the new alarm priorities you configured; otherwise, saved changes will not be recognized until Oracle Utilities Network Management System services are restarted.
• Export Table…: Displays the SQL needed to create the data displayed in this table.
