The Add / Edit Alarm Classes dialog box allows you to create or edit existing alarm class. The tool has the following fields:
• The Name column defines the name of the class
• The Active column defines whether the class is active or not.
The following buttons are available:
• Save Changes: Saves the alarm class and closed the dialog.
• Cancel Edit: Cancels the action and closes the dialog.
Understanding the Categories Tab
The Categories tab defines the available alarm categories in the system. The categories allow alarms to be further categorized within an alarm class.
The Categories table has the following columns:
• The Class column defines the alarm class the category is associated with.
• The Name column defines the name of the category
• The Active column defines whether the category is active or not.
The following right click options are available:
• Add New Category…: Opens the Add / Edit Alarm Category dialog box to allow a new row to be created.
• Edit…: Opens the Add / Edit Alarm Category dialog box to allow the selected row to be edited.
• Remove: Removes the alarm category.
• The Add … button opens the Add / Edit Alarm Category dialog box to allow a new category to be created.
• The Remove… button deletes the selected category.
• Edit…: Opens the Add / Edit Alarm Category dialog box with the selected rows values.
• Refresh: Refreshes the screen.
• Recache Services: Causes the Oracle Utilities Network Management System services to recache with the new alarm categories you configured; otherwise, saved changes will not be recognized until Oracle Utilities Network Management System services are restarted.
• Export Table…: Displays the SQL needed to create the data displayed in this table.
