Menu Option | Description |
Set Wild Card Searching • Before • After • Both | Options for setting a wild card searches: Before, After, or Both. Note that you do not have to add a wild card character (*). Example: using the "After" wild card search. Name: Mary S returns: • Mary S Abbott • ... • Mary Szbrinski |
Use Sound Search | Returns searches with "sounds like" matches. Example: Use Sound Search Name: Fredric returns: • Fredric • Fredrick • Frederick • Fred • Freda |
Use Exact Match Search | Returns only exact matches. |
Set Max Searching Results | Opens the Set Maximum Searching Result dialog box where you can set the limit for matches to return. The system will display a message when a search returns over 200 results, which is the maximum allowed by default. |
