Installation Process Overview
This section provides a high level overview of the basic steps to install the Oracle Utilities Network Management System software.
Install Database
Oracle Utilities Network Management System supports the Oracle Relational Database Management System (RDBMS). The RDBMS must be properly installed and configured prior to using the Oracle Utilities Network Management System software.
Reference Information
• For information on installing the database software, see the Oracle RDBMS documentation.
• For information on configuring Oracle RDBMS for use with the Oracle Utilities Network Management System software, see the “Database Configuration” chapter of the Oracle Utilities Network Management System Configuration Guide.
Install Non-NMS Oracle and Third Party Software
Please refer to the Oracle Utilities Network Management System Installation Guide for details of installing unbundled non-NMS Oracle and third party products needed for proper execution of the application software. Other Oracle and third party products may need to be downloaded or installed from other vendor-supplied media.
Install Oracle Utilities Network Management Software
Please refer to the Oracle Utilities Network Management System Installation Guide for details of installing the application software. Some steps included in the install guide require specific actions based on the Unix operating system or Java Application server that you will be using. Pay special attention to follow each step exactly as documented in the installation guide.
Configure Oracle Utilities Network Management System Components
Please refer to the Oracle Utilities Network Management System Configuration Guide for details of configuring the various components of your Oracle Utilities Network Management System.
