Locked table columns may be unlocked by right-clicking the table header and selecting Unlock Columns from the context menu. To lock columns, right-click the table header of the column you want to be the rightmost locked columns.
Copying Table Data
Many tables in Oracle Utilities Network Management System applications and tools allow data to be copied and pasted into other applications.
1. Select the row or rows to be copied.
2. Press Control+C to copy the row data.
3. In the target application, such as a spreadsheet application, press Control+V to paste the data.
Exporting Table Data
Many tables in Oracle Utilities Network Management System applications and tools allow data to be exported as comma separated values (csv) files. If the export option is available, it will typically be listed under the tool's File menu as Export Table... or the export table button () may be available from a toolbar.
Understanding Table Cell Tooltips
If a table cell’s content is truncated, you may hover your mouse over the cell to see the full value.
