Creating a User-Defined Filter
To create a filter, complete these steps:
1. In the Filter pane, right-click the folder where you want to place the filter, then select New Filter… from the context menu.
2. Enter a Name for the filter in the Name field.
3. Define a set of filter criteria in the Criterion fields. For each filter criterion, specify:
• The column to filter.
• The operator to use.
• The values to match.
4. Click Add to List.
5. (Optional) Add more criteria, if required. You can click Apply at any time to see the matching results.
6. When you have finished adding the filter criteria, click OK.
