Creating Folders and Sub Folders
Depending on your role, you can create folders within the Global, Shared, or Personal structures. Folders can be used to organize filters into hierarchic structures.
1. To create a folder, right-click a filter structure and choose New Folder….
2. Enter a name. The folder is created.
You can also create folders inside other folders.
Folders and top-level structures can be collapsed or expanded by clicking on the icon. Once the folder has been created you can add, move, or copy filters to it.
