Favorite Filters
If you have filters you access frequently, you can add them to the Favorites structure.
• Right-click a filter and select Add to Favorites or drag the filter to the Favorites structure. The filter is added as a shortcut to the Favorites structure.
• To remove a favorite shortcut, right-click and select Remove from Favorites.
Note: The source filter is not affected by Remove from Favorites.
• To find a Favorite’s source filter, right click the shortcut and choose Find Target Filter. The source filter is displayed and highlighted.
Note: If the source filter name is edited, the shortcut in the Favorites pane updates with the new name.
