Button | Description |
Used to preview the previous page in a multi-page output. | |
Used to preview the next page in a multi-page output. | |
Used to zoom out on the contents of the preview. | |
Used to zoom in on the contents of the preview. | |
Used to scale out the font used for the print output. | |
Used to scale in the font used for the print output. | |
Toggles the page orientation of the output between portrait and landscape. | |
Brings up the Page Setup dialog box, which allows you to select paper size and source, set page orientation, set margins, and select the printer. | |
Reverts the preview window back to its default settings. | |
Sends the print output to your selected printer, and then closes the Print Preview dialog box. | |
Close | Closes the Print Preview dialog box without printing any output. |
