Creating Window Frames
A frame is a user-defined container that can be used to organize Web Workspace tools. The frame (and the tools that you place within it) can then be stored as part of a Workspace Layout (see “Managing Your Workspace Layout” for information).
To create a frame:
1. From the Web Workspace File menu, select New Frame… to open the New Frame dialog box.
2. In the Frame Name field, enter a name for the frame.
3. Add dock pane tools to the frame, as described in “Understanding Dock Panes”.
4. Create other frames, as required.
Notes:
• Once a frame has been created, its name is displayed at the bottom of the Web Workspace Tools menu. If you close a frame you can redisplay it from this menu.
• Any frames that you have configured are stored when you save your Workspace Layouts (see “Managing Your Workspace Layout” for information).
