Switching Between Tools Using the Keyboard
You can switch between open tools by pressing Ctrl+Tab, which will display a list of open applications. The list is ordered so the most recently used tools are at the top. You can cycle through the applications by continuing to hold the Ctrl key and pressing Tab until the tool you wish to switch to is highlighted; the highlighted tool will become active when you release the Ctrl key. You can go backwards in the list by pressing Ctrl+Shift+Tab. You can also hold the Tab key to quickly cycle through the entries in the list, which may be useful when you have many tools open.
Saving and Restoring Workspace Preferences
Web Workspace starts with a standard configuration for window locations and sizes, font sizes, visible tools, and tool settings, such as column size and order. You can make adjustment to the workspace and then save those changes for future sessions.
Preferences are saved for the following features:
General
Accessible Mode selection
Windows
The currently open windows are saved and reopened when you login. This feature is restricted to the following windows:
• Condition Summary
• Crew Actions
• Viewers (each Viewer is saved separately)
• Service Alarms
• SCADA Summary
• Work Agendas (each Work Agenda is saved separately)
• FLM Summary
Table Attributes
• Column widths
• Column ordering
• Locked columns
• Current sort
• Current filter
Viewer Settings
• Unload on Focus
• Fixed Size
• Search Type
• Search Case
• Search Max Results
• Spatial Landbase
• Declutter
• Predicted Highlight Enable
• Conductor State Highlight
• Warnings Highlight
• Violations Highlight
Filters
• Size and collapsed state of the Filter side panes
• Filter folder collapsed/expanded state
• Selected filter
Note: Ensure that only one switch plan is displayed when you save preferences (the system will not allow preferences to be saved if multiple sheets are open). The preferences for that sheet will be applied to all sheet types to the extent possible.
