Trace Type | Description |
To Source | Traces from the selected device to its energizing source. |
All Connected | Traces from the selected device to all connected devices, stopping only at energizing sources. |
To Transformer | Traces from the selected device to upstream and downstream transformers. |
To Switch | Traces from the selected device to upstream and downstream switches. |
To Device Class | Traces from the selected device to a device class. Click the Search button () to open the Select Class dialog box, which displays a tree list of device classes. Multiple device classes can be chosen by holding down the CTRL key when selecting additional classes. After making your selection, click the OK button to close the dialog box. |
To Open Points | Traces from the selected device to all directly-connected open points on the feeder. |
To Nominally Open Points | Traces from the selected device to all directly connected nominally open points on the feeder. |
