Commissioning and Decommissioning Devices
To commission or decommission sets of devices, perform the following steps:
1. In the Viewer, load the pending device changes you wish to modify. You can select multiple devices.
2. Enable the Show Pending Devices option in the Hide/Display dialog box.
3. Switch to study mode if you don't want to affect the real-time model.
4. Select Commissioning Tool... from the Viewer's Actions menu. Selected devices pending approval are listed in the Waiting for Approval pane.
5. Select the devices you want to commission or decommission, then click the Approve () button.
Notes:
• Devices being decommissioned are no longer part of the model and are immediately de-energized, as are downstream devices.
• Commissioned devices immediately become part of the model and energization is recalculated (that is, a newly commissioned device attached to an energized conductor will become energized).
