Creating a New Save Case
To create a new save case, you will first perform operations in study mode and then open the Save Case Management tool.
1. In the Save Case Management tool, click the Save... button () to open the Save Case Details dialog box.
2. Enter a name for the save case in the Save Case field.
3. Enter a description for the save case.
4. Click the Save button to save the save case.
Note: If a row was selected in the Save Case Management tool's Save Cases table, the Save Case and the Description fields will be populated with the name and description of the selected save case. If you click Save, an Overwrite Save Case? dialog box will ask you if you want to overwrite the save case with the operations in your study session.
• Click Yes to overwrite the save case.
• Click No to go back to the Save Case Details dialog box and enter a new name and description.
If you select a row in the Save Case Management tool, but want to create a new save case, click outside of a table row to deselect the row.
Understanding the Save Case Details Dialog Box
The Save Case Details dialog box contains fields, buttons, and a data table listing the operations performed in a study session.
Save Case Details Fields
The Save Case Details dialog box contains the following fields and buttons:
• The Save Case field allows you to enter a name for the save case.
• The Description field allows you to enter a description for the save case.
Save Case Details Buttons
• The Save button saves the save case with the name entered in the Save Case field. The button is only sensitized when a name has been entered.
• The Help... button launches online help for the Save Case Management tool.
• The Cancel button closes the dialog box without saving any changes.
Save Case Changes Table Fields
The current study session's operations are listed in the Save Case Changes table. The Save Case Changes table contains the following information:
• The Operation field displays the type of operation performed.
• The Device field displays the operated device's ID.
• The Phases field displays the phases affected by the operation.
