Understanding the Tags Dialog Box
The Tags dialog box allows you to create and edit editable tags. The Tags dialog box displays the following fields and buttons:
Fields
The Tags pane contains a table that lists existing tags.
The Edit Log pane contains a table that lists any previous versions of the selected tag that exist.
The Tag # field displays the tag's external ID.
The Tag Text field displays the text of the selected tag.
Buttons
The New button allows you to create a new tag.
The Edit button allows you to edit a tag selected in the Tags pane.
The Delete button deletes the tag selected in the Tags pane.
The Help... button launches online help for the Tags dialog box.
The Cancel button closes the Tags dialog box without saving changes.
