Using the User Log
The User Log displays a log of actions taken by a user.
To open the User Log, select User Log... from the Web Workspace Tools menu.
The User Log window displays the following fields:
• The User ID field opens with the current user's identification, but the field may be edited to load log entries for a different user; for a different user log, enter their user ID and click Load User Log button ().
• The Begin Time and End Time fields allow you to filter the User Log by time. To load log entries for a specific time period:
• Enter a starting date in the Begin Time field.
• Enter an ending date in the End Time field.
Note: You can enter a beginning date, an ending date, or both.
• Click the Load User Log button (). The list is refreshed to display only entries with a date and time greater than or equal to the Begin Time and less than or equal to the End Time.
• The User Comment field allows you to enter a user comment log entry.
• The User Log Table has the following fields:
• The Date/Time field displays the date/time at which the log entry occurred.
• The Event field displays the Event # associated with the log entry.
• The Text field displays a description of the log entry.
• The Sheet/Doc # field displays the switching sheet or safety document number associated with the log entry.
Menus and Toolbar
