Menu Option | Description | Toolbar Icon |
Save | Saves the current event. If the event has already been completed, you are prompted to provide a reason for the update. | |
Print Tab... | Opens the Print Preview dialog box and allows you to print the current contents of the Job Actions tab. | |
Print All... | Opens the Print Preview dialog box and allows you to print the contents of all three Event Details tabs. | |
Exit | Exits Event Details. You must press the Save button before pressing the Exit button if you wish to save any revisions you may have made. | -- |
