Understanding the Damage Specifics Section
Section Affected allows you to specific the section affected by the damage. You can select from a list or enter a value manually.
Location allows you to specify the damage location. You can select from a list or enter a value manually.
The Hazard check box indicates a hazardous situation.
The Street Light Damage check box indicates whether street light damage is reported.
The Crew Types indicates the types of crews needed to repair the damage. Enter the number of each crew type.
Comments contains any remarks associated with the damage specifics.
