Finding the Event a Crew is En Route To
To find the event a crew is en route to, select the crew in the Crew Actions window and then select the View toolbar button or select View... from the Actions menu. The event row is highlighted in the Work Agenda Trouble Events list, and Viewer 1 focuses on the device associated with the en route event.
Note: The Work Agenda event row will only be highlighted if the Work Agenda window is open and the event is on the list you currently have displayed in the Work Agenda window. The Viewer will only focus on the device if you have the Viewer 1 window open.
