Moving a Crew from Crew Info
To move a crew, complete these steps:
1. In the Active Jobs pane, click the Move Crew… button. The Choose Work Location dialog box opens.
2. Select the new device location in the Viewer window or select an event in the Work Agenda list that has the same device as the one where the crew is currently working.
3. Click OK. The crew symbol moves on the Viewer map and the crew's Device updates in the Crew Info and Crew Actions windows. The crew remains en route to/onsite at that same event.
Releasing Crews from an Event
You may release crews from an en route/onsite event using the Work Agenda, the Crew Actions Crew Info window, or from event or crew symbology in the Viewer.
