Turning Accessibility of Projections Back On/Removing Overrides
To turn the accessibility of the Storm Management estimates back on and/or remove ERT Overrides, complete these steps:
1. Do one of the following:
• Click the ERT Override button on the toolbar, or
• Select the ERT Override... option from the System menu. The ERT Override dialog box opens.
2. Select the row that corresponds to the zone for which you want to turn the accessibility of estimates back on/remove the applied ERT Override.
3. Press the Esc key.
4. Click Remove.
5. Repeat previous steps as needed.
6. Click OK. The following occurs:
• All eligible events immediately receive the most recently calculated Storm Management estimates.
• If all rows have been removed from the ERT Override table, the status bar indicates ERT Override is off.
