Printing ERT Overrides
To print the contents of the ERT Override dialog box, complete these steps:
1. Do one of the following:
• Click the ERT Override button on the toolbar, or
• Select the ERT Override... option from the System menu. The ERT Override dialog box opens.
2. Click the Print… button. The Print Preview dialog box opens.
3. Adjust the scale, orientation, and page setup as desired.
4. Click the Print button on the toolbar to print the pages. The Print Preview dialog box disappears and the print output appears at your selected printer.
Manual Overrides
It actual averages may be significantly different from the historical averages. The Storm Report's % Change row lets you temporarily manually override each category of historical averages. The percentage you enter (within the allowed range of 1% to 32767%) changes the lookup values that are used in the calculation of the estimates. This functionality is only available when the currently selected control zone is at the simulation level.
