Storm Administration Table
The Storm Administration table displays the following fields and buttons:
• The Storm Name column contains the name of the storm as defined in the Define Storm dialog box. This field is not editable.
• The Zone column contains the name of the control zone affected by this storm. Unless explicitly defined elsewhere in the table, all of the children of the control zone are considered part of this storm as well.
• The Special Condition column contains the storm type indicating a predefined condition of the storm, as defined in the Define Storm dialog box.
• The Start Date column contains the date and time when the storm began in the zone, as defined in the Define Storm dialog box.
• The End Date column contains the date and time when the storm ended in the zone, as defined in the Define Storm dialog box.
• The Storm Level column indicates the severity of the storm, as defined in the Define Storm dialog box.
• The Excludable Period Start Date column contains the start date and time of the portion of the storm that can be excluded when reporting reliability metrics.
• The Excludable Period End Date column contains the end date and time of the portion of the storm that can be excluded when reporting reliability metrics.
• The Excludable Period Comment column contains the comments for this excludable period.
