Group Manager Tab
The Group Manager tab contains the following information:
• The Groups pane displays a list of all groups in the system. A group does not need to contain any contacts, nor does it need to be associated with a notification parameter.
• The Add button on the Groups pane opens the Add Group dialog box. This dialog box allows a new, empty group to be created. Each group must have a unique name.
• The Remove button on the Groups pane deletes the group from the database. This will also delete all parameters associated with the group, but contacts that are members of the group are not deleted.
• The Contacts pane displays a list of the individual members in the selected group.
• The Add button on the Contacts pane opens the Add Contact dialog box. This dialog box allows contacts to be added to the selected group.
• The Remove button on the Contacts pane removes the selected contact from the selected group.
• The Message Types pane displays a list of the available notification message types that the selected group can receive.
• The Message Formats pane contains information regarding the transforms for the selected message type.
• The Email field displays the transform, in the form of an XSL file, that will be applied to the notifications of the selected notification type bound for an email destination corresponding to members of the selected group.
• The Text/SMS field displays the transform, in the form of an XSL file, that will be applied to the notifications of the selected notification type bound for a Text/SMS destination corresponding to members of the selected group.
• The Script field displays the transform, in the form of an XSL file, that will be applied to the notifications of the selected notification type bound for a script destination corresponding to members of the selected group. Leaving the Script field empty would cause raw XML to be delivered to the script.
• The Modify Transformation button saves the XSL file information to the database for the selected group and notification type.
Note: You must verify that the specified XSL file is available in the designated location.
