Adding Accounts
The Add Account dialog box opens once you press the Add button on the Utility Customers tab. This dialog box allows you to add a critical customer into Service Alert.
The Add Account dialog box displays the following fields and buttons:
The Search Text field displays the text used to search for a critical customer account. The text varies based on the search parameter.
The Search Parameter field displays the current search parameter. The available parameters are Account Number, Account Name, Phone Number, Address, City State, and Zip Code.
The Search button performs a critical customer search within the Oracle Utilities Network Management System database based upon the Search Text and Search Parameter.
The Clear button clears the Search Text field and the search results table.
The Account Number column displays the account number of the critical customer.
The Account Name column displays the account name of the critical customer.
The Phone Number column displays the phone number of the critical customer.
The Address column displays the address of the critical customer.
The City State column displays the city and state portion of the critical customer's address.
The Zip Code column displays the zip code of the critical customer.
The Critical Types column lists the customer's critical classification.
The OK button adds the customer to Service Alert and closes the Add Account dialog box.
The Cancel button closes the Add Account dialog box without adding the customer to Service Alert.
