Choosing the Analog Measurements to Display in the Viewer
An Administration user type may choose which measurement types (for example, Amps A|B|C, kV A|B|C, kW, etc.) to display in the Viewer for a particular device.
Note: Users must have Measurements selected in the Viewer Hide/Display dialog box to see any measurements.
To add or remove a measurement type for a device, first load the Viewer map containing the device, then select the SCADA summary row for the device measurement type, right-click, and choose one of the following options:
• Show Measurement in Viewer: Shows the selected measurement in the Viewer.
• Hide Measurement in Viewer: Hides a measurement in the Viewer.
