Resetting Operation Text
Operation text that has been manually entered may be reset to its original value by following the following steps:
Right-click to select the row and open the option menu.
Select Reset Operation Text. The Reset Operation Text dialog box will open to confirm that you want to change the Operation text back to its original value.
Click Yes to reset the value.
Note: Click No to close the dialog box and leave the Operation text unchanged.
