Finding and Replacing Text in the Steps
The Text tab of the Find and Replace dialog box allows you to find and replace occurrences of text in editable fields within the switching steps.
Note: Not all editable fields allow Find and Replace; the project configuration determines what fields are editable. Base Product configuration allows you to find text in the step fields Operation, Device, Details, Executed By, Instructed by, Instructed To, Address and Comments. However, you can only replace text in the editable fields Details, Address and Comments.
To find occurrences of a device within the Steps list, complete these steps:
1. Open the switching sheet.
2. Click on the Steps tab.
3. Click the Find and Replace... button on the Steps tab toolbar. The Find and Replace dialog box opens.
4. Click the Text tab, if not already selected.
5. Enter the search term in the Find field.
6. Click the Find Next button to navigate through the list of steps, highlighting each occurrence of the entered search term.
7. To replace an instance of the search term, enter the replacement text in the Replace with field and click Replace. Repeat as necessary.
Note: If you attempt to replace text in a non-editable field, a message will notify you that it cannot be replaced.
