Changing Start Date
The Change Start Date? dialog box appears when you edit the Completed Date of a step that is part of a partial restoration. The outage start times for the related events are not updated. The system does not have enough information to decide which steps should be updated without input.
The dialog box allows to select related steps that should also have their outage start time modified. Click OK to change execution time or click Cancel to abort the change.
