Deleting and Restoring Customers from the List
To remove a customer from the list, right-click the customer and select Delete from the context menu. The row is highlighted in red.
Note: Removing the customer from the list does not remove the customer from the model; it simply marks the customer as deleted from the list. If you regenerate the list, the customer will still be marked as deleted. If the customer is impacted multiple times, then that customer will be marked as deleted in each of the lists.
To restore (un-delete) a customer, right-click the customer and select Undelete from the context menu.
To restore all previously deleted customers, click the Reset all Deleted Impacted Customers button. All red highlighting is removed.
