Saving a Viewing Area
To save a viewing area, complete these steps:
1. In the Viewer window, navigate to the area of the map that you want to save as a viewing area.
2. On the View Areas tab in the Web Switching Management window, click one of the Save Map buttons on the toolbar.
• Click the Save View Area 1 button () to save the map area that is currently displayed in Viewer 1.
• Click the Save View Area 1 button () to save the map area that is currently displayed in Viewer 2.
The new view area is added to the bottom of the list of saved views on the View Areas tab.
3. In the Description field, enter a meaningful name that describes the viewing area.
4. If you would like this viewing area to be loaded automatically the next time this switching sheet is opened, select the Viewer from the Auto Load in Viewer drop-down list.
Note: The application will only allow you to select one saved viewing area to be auto-loaded for each Viewer.
