Deleting a Saved Viewing Area
To delete a saved viewing area that you no longer need, complete these steps:
1. On the View Areas tab, select the viewing area you want to delete.
2. Click the Delete button (). The viewing area is removed from the list. The All Devices dynamic view area cannot be deleted from the list.
Viewing the Audit Log
The Tracking/Audit Log tab displays the current state of the switching sheet and allows you to transition to a different state. You can provide comments to explain the reason or circumstances around the transition in the Sheet State Tracking pane. See “Changing the Switching Sheet State” for more information, including valid switching states.
The Audit Log table contains a list of status changes the sheet has gone through since it was created. An entry is added to the log whenever changes occur to the sheet state, including (but not limited to) status changes, sheet ownership changes, generation of the impacted customer list, and sheet version check-ins.
The Audit Log table contains the following fields and buttons:
• Entry Date displays the Date and Time when the change was made.
• Sheet Version displays the version of the sheet when the change was made.
• Sheet State displays the state of the sheet when the change was made. (See “Switching Sheet States” for state descriptions.)
• Entry By displays the user who initiated the change.
• Details displays a brief description of the audit entry.
Note: You cannot change any information for existing entries in the audit log table.
As with other list displays, you can click and drag column headers to rearrange the order of columns. You can also re‑sort the list by clicking on the Entry Date column header. By default, log entries are displayed in ascending chronological order.
