Open or Create New Switching Sheet
The Open or Create New Switching Sheet dialog box will open with the options of creating a new Emergency or Outage Correction switching sheet (from the Switching Sheet Types pane) or opening an existing switching sheet that is associated to the event from the Pre-Created Switching Sheets pane.
Create New Sheet
1. Select the Emergency sheet type from the Switching Sheet Types pane. The Create button is enabled.
2. Click the Create button.
3. The Web Switching Management window displays the new emergency sheet.
Open an Existing Sheet
1. Select an existing sheet from the Pre-Created Switching Sheets list. The Open button is enabled.
2. Click the Open button.
3. The Web Switching Management window will load the selected switching sheet.
Alternative Methods of Creating an Emergency Switching Sheet
• From a device's Control Tool, select Switching Plans... and then select Create Emergency Switching Sheet... to create a new switching sheet.
• From the File menu, select New and then select Switching Sheet... to display the New Switching Sheet window. Select Emergency as the sheet type and click Create.
Note: An emergency switching sheet created this way will not be associated with an event.
