Sort Menu
The table below describes the options available on the Sort menu.
Menu Option
Description
Icon
Sort Dialog...
Opens the Sort dialog, allowing you to create, modify, apply, and save user-defined sorts. See
“Using the Sort Dialog Box”
Doc #
Applies the default sort, which is the doc # in descending order.
This site works best with JavaScript enabled
